Volvo S60 reading
Hello.
I want to read and write my Volvo S60 ecu.
Kess v2 said wake up error and cant read.
This is EDC15C2 ecu, Volvo S60 2.4D 96kw
Someone have instructions how to read and write this ecu?
I found this instructions..
http://blog.obdii365.com/2018/04/09/volv...or-fgtech/
Is the pin 24 inside the ecu?
The end of site is wiring picture, is it correct?
(09-12-2019, 01:19 PM)qaqaqa288 Wrote: Hello.
yes it corerect ,you need to run in boot mode to read this control unit along the k-line,mpps also reads this block
Pc
Hi!
Trying to read this ecu but no luck.
Pin 24 must be all time grounded?
I follow obdii365 instruction by grounding this pin (see picture)
https://www.dropbox.com/s/btair235rsd1ii...9.jpg?dl=0
Video - https://youtu.be/ZRnTXIXUXDU
Using Ksuite 2.08
IO terminal works good with this ECU via obd.
Wysłane z mojego SM-N970F przy użyciu Tapatalka
If I helped - click thanks and give rep BlushBlush
06-01-2020, 09:25 PM
Ford
05-28-2020, 04:24 PM
04-25-2020, 09:25 PM
Volvo
04-07-2020, 01:54 AM
04-01-2020, 03:03 PM
