Volvo V70 1.6 D -2010 and OBD support....
Motor type should be D4164T, 80kw. Is OBD kline/CAN wiring complete done? Volvo is well known this issue(no wired to OBD)
Reworked and updated Galletto 0475 + Kess 2.47/5.017 + Ktag 2.25/7.020 and now KESS 5.028/2.47 VR and KTAG 8.000/2.47!!!049
SMOK UHDS can read eprom and flash in EDC16C34,  via OBD
MMI 2G High, 3G B/H, RNS-E, RNS310, RNS315, RNS510, RNS850 PL Menu, lector, US to EU
NISSAN LCN1 PL Menu, lector, sd unlock
BMW CCC PL menu, lector
PL menu and lector to many cars
Thanks given by: Bimmeristi
IO terminal with Bosch plug-in can do it Volvo EDC16C34 via obd.
Wysłane z mojego SM-N970F przy użyciu Tapatalka
If I helped - click thanks and give rep BlushBlush
...... so OBD must be wired(kline/CAN) then. Does some know is S40(same motor code) equal ECU?And can use same protocol(Kess or MPPS).....
Yea, exactly Volvo don't have k line on obd port.
Make it by bdm.
Exactly, BDM for this ECU is safe and simple.
Mpps working like dream on bench with obd adapter for that ecu.
No need opening.
(11-10-2019, 10:59 PM)Zeder Wrote: Mpps working like dream on bench with obd adapter for that ecu.
No need opening.
What protocol should use? There is at least protocol for S40 with k-line, should use this in bench? For V70 there is <2008 protocol only
(11-10-2019, 10:21 PM)dudus8 Wrote: Yea, exactly Volvo don't have k line on obd port.
You mean generally or also for this?
05-19-2020, 02:30 AM
05-14-2020, 04:26 PM
05-11-2020, 04:36 PM
05-08-2020, 12:12 PM
