  • 9 Vote(s) - 3.22 Average
W124 E 260. engine no acceleration
Hi, I have this Mercedes 260E model year 1991 the engine does not accelerate is there a way to test the fuel distributor, I had replaced the two fuel pumps a year ago, can anyone give advice how to proceed.
Thanks,
Sebastian
Since you haven't provided specific vehicle info, from my experience I want to assume that the engine is M103.940 straight 6Huh!
1. Assuming EZL(ignition control unit N1/2)
The ignition system is preset by ECU unlike the M102 where it's adjustable via the spark distributor and a timing light, but for proper diagnosis purposes just get a timing light and confirm the fixed ignition characteristics at idle speed!
read wis document ra1500ke3c020x for further info!
HAVE GOOD SPARK PLUGS FITTED!
2. FUEL SYSTEM
This step comes after you have confirmed step 1 that the ignition system is not retarded!
The fuel system settings is key for the mechanical(electro) KE-Jetronic by Benz!
YOU HAVE TO DO A BASIC SETTING FOR THE FD(FUEL DISTRIBUTOR) WITH RESPECT TO THE MECHANICAL AIR FLOW METER! :-
a. ASSUMING NEW FUEL FILTER (& PRE-FILTER). VEHICLE SHOULD HAVE ENOUGH GAS >1/4 TANK AT LEAST, REMOVE AIR CLEANER HOUSING, BRIDGE THE FUEL RELAY TERMINAL 87 & 30!
b. WITH ENGINE OFF! GET A 12MM SPANNER AND LOOSEN OFF ONE OF THE DELIVERY PIPES FROM FD TO NOZZLE, USING A 3MM ALLEN KEY YOU CAN SET THE AIR-FLOW METER DISPLACEMENT BY DEFLECTING THE AIRFLOW METER PLATE SLIGHTLY BASED ON THE SMALL EXTENT THAT YOU IMAGINE IS THE DEFLECTION FOR IDLE SPEED TAKING NOTE ON FUEL BEING DELIVERED AT THE 12MM ORIFICE ON THE FD WHICH YOU OPENED!
c.THEN REFIT THE PIPE AND START THE ENGINE TO IDLE AT NORMAL WORKING TEMP 60-80DEGREES,
d. IF THERE'S BLACK SMOKE AT EXHAUST (MIXTURE IS TOO RICH, IF EXHAUST IS TOO HOT MIXTURE IS TOO LEAN)
remove the fuel relay bridge
e. IF ENGINE IS SLUGGISH AFTER TUNE UP,CHOKE RETURN PIPE AND SEE IF IT IMPROVES, IF IT DOES, THEN YOUR FUEL PRESSURE ACCUMULATOR (NEXT TO FUEL PUMP AND FILTER IS FAULTY) IF IT DOESN'T IMPROVE THEN YOUR FUEL PUMP IS WEAK AS WELL.
I am suggesting the above assuming that the engine is mechanically sound in terms of timing and compression!
Getting parts for these classics is tricky nowadays, fuel injection systems are prone to failure due to under usage!
“We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
Thanks given by: Rocinante , bnunes39
First, check the overvoltage relay and fuse on relay.
Disconnect ECU and try again. This engine works without ecu. ECU is only for coldstart period and lambda correction. If it accelerate again, electric trouble, write again in thread to find solution.
If error the same, first check for leaks on intake manifold (big black tube under airflow-meter), compression and timing chain. Then, check the ignition system. How old are the spark plugs and cables ? How old ignition distributor cab and finger ? Did you check for strange sparks in a dark room ? If spark condition is fine, take a look to the fuel system.
How old is the fuel filter ? How old is the fuel ? How much is fuel pressure ?
I forgot to ask you if your car has a 722.4/722.5 transmission, with the red cable attached to the throttle mechanism,
Check the lead wires ( High tension leads) in a dark room, to rule out that the vehicle has a hesitation!
