1,545
Thanks Given: 834
Thanks Received: 3312 (599 Posts)
1,500
108
Have a car, 1997 ml320 not reading a new key.
AAM cannot detect transponder. We replaced antenna ring.
8 keys registered to AAM. Is there a limit and am I missing something?
No drive auth to start is the only code in ECM
72
Thanks Given: 706
Thanks Received: 583 (231 Posts)
336
Limit is 8 keys. In your year ML, DAS is incorporated into the AAM. You will need from the same donor car ECM,AAM, Starter switch,transponder,keys........
Art
1,545
Thanks Given: 834
1,500
108
can I just get OEM AAM? align to ECM?
72
Thanks Given: 706
336
In your year ML, the AAM is "locked" to your ECM. All has to be changed.
Art
397
Thanks Given: 4687
Thanks Received: 1897 (598 Posts)
1,354
96
I just install immo emulator in these old ME2.0 and problem solved.
2,095
Thanks Given: 14574
6,536
46
(02-10-2017, 07:03 PM)bawarek Wrote: I just install immo emulator in these old ME2.0 and problem solved.
Could you be a little more specific and possibly provide some links?
I run into the 8 key limit all the time now and Mercedes has the remote keys on intergalactic back order now..
1,545
Thanks Given: 834
1,500
108
I'm very interested in this, I was about to sell ECU, AAM, switch, and key used.
(02-10-2017, 09:42 PM)Rocinante Wrote: I run into the 8 key limit all the time now and Mercedes has the remote keys on intergalactic back order now..
Keys on backorder? we just ordered a remote key no problem.
397
Thanks Given: 4687
1,354
96
Buy CR1 emulator on Aliexpress, then virginize ME, install emulator inside ME (4 wires positive, negative, CAN-L, CAN-H) then do initial start-up. Now the ME is a "self-contained" with the immobilizer inside. It will start and run installed on any car.
