  • 35 Vote(s) - 3.54 Average
Activate Steering Wheel Paddles on Smart 451 ? It works !!!
hi there ...
i hope i can ask my question here?
And also i hope you can understand my english, sorry for that ...
Here is my question.
I got a working xentry/das 07-2013 with the fixed dll-file and a china multiplexer.
I want to activate steering wheel paddles on my smart 451 ...
Are the paddles activated after pressing the F2 Button on xentry/das, or is there anything to do?
What is the scn-coding? And is the scn-coding nesesserry for activation ?
Can I activate the Paddles bevor putting in the new Steering Wheel, or is an activation only after
the build in possible ...
Thanks for a litte help ... No.Trace
IBM ThinkPad T60 - DAS/Xentry/EPC/WIS 2018 with C3 Mux - Lenovo Tab8 with DDT4All - Galletto 1260 - ELM327 USB -
If smart will work like the Mercedes cars and I suppose it will, you will need SCN coding. Generally if you do not know what SCN coding is - you should stop what you are doing and learn a little bit more..
SCN coding is only available with a direct access to mercedes benz which many users (including me) got...
By the way, there is another way... You can do it with Vediamo. This is the only offline method I know. But I do not think that you can use Vediamo but you can try it Wink
Hi there ...
and thanks for your help ... i'll learn more here on mhh Wink
i have activated my paddles etc. on my smart 450 that was easy and now i got a
smart 451 and i looks like it is different ... so i need a little help.
i also got a tan code for the paddles but everything is new on 451 ?!
Where can i get a scn direct access an how much will that be ?
Greetings No.Trace
Hi there ...
So, yesterday i tried ... i put my DAS and the Multiplexer on the Smart
and pressed "F2" to continue after the question if i want to activate the paddles.
Something happened an than i got an error-message that something couldn't be downloaded ...
After that i made en error-scan and got an error "F" - cable break on paddle shift -
The new Steering Wheel isn't in the car ... so the error is ok ... i think.
When i now put in the new Streering Wheel with Paddles, they will work ... i hope Wink
On my old 450 Smart it was the same way ...
Greetings ... No.Trace !!!
Hi there ...
Just for your information ... it works !
Just activate the Paddle Shift with "F2" and the fixed dll
put the paddles on the steering wheel oder get a steering wheel with paddles
and everything is good Wink
THX and greeting ... No.Trace
Thanks given by: Rocinante , SmartGuy , Fogiu , pesona
(08-20-2014, 03:01 PM)No.Trace Wrote: Hi there ...
HI,
Can you tell me how you connect puddles on your 450? Did you use brabus pcb adapter or you made new adapter by yourself? There is only one wire coming from the wheel and you somehow have to separate signal from that wire to transmit it to three different channels. Can you help me?
Hi there ...
this posts are about paddle shift on th smart 451 not the smart 450.
on the smart 450 you have different ways for paddle shift.
1. buy a 3 spoke steering wheel with original paddles
Code:
hxxp://fq101.co.uk/how-to-guides/fortwo-450/interior/154-fitting-brabus-paddle-wheel-698cc
2. pimp you "horn ring" with resistors
Code:
hxxp://www.evilution.co.uk/index.php?menu=interior&mod=424
I hope i could help you a littel bit.
CU No.Trace
Thanks given by: pesona , fatal1ty
(05-11-2016, 12:46 PM)No.Trace Wrote: Hi there ...
Code:
Code:
CU No.Trace
can you explain in wicht menu did you enable paddle ?
