  • 6 Vote(s) - 3 Average
W202 EIS - EZS 0D69J Repair
Hi there folks....
So I had a client with a W202 that just required a spare key.....
I removed the External 0D69J as I usually do and read it and then put it back to solder. I left the Hotair station on and got busy talking on the phone and so it overheated the chip and board.
I managed to write the data which I saved on the PC to a 1D69J which I had laying around.
I then generated keys and tested the keys on the bench and they worked.
However when I gave the EIS and keys to client he says that Ignition comes on, Dash lights up buyt car won't crank the engine.
I got the EIS back and no removed the Internal Eeprom and External and read them both and see that the data differs.... The key info seems to differ.
Can somebody help match the internal and external eeprom data for me please.......
Do I need to change both to 1D69J or is it fine with 1 X 0D69J and the other 1D69J?
Thanks alot
W202 - 11-10-2017.rar
File Type: .rar
Downloaded: 29 times
This ext is hash error
repaired, try and report
1.zip
File Type: .zip
Downloaded: 21 times
Thanks given by: obeids , KriyenKPp
#3
(10-12-2017, 11:15 AM)leaser Wrote: This ext is hash error
Hi thanks
Can I use the 1D69J that I got from another EIS and write this file from you?
Somebody was saying that I must get exact same EEPROM from SAME part number EIS.
Hi.
I got another exact same EIS and loaded the External MCU dump to both and the car starts and drives. Everything seems to work besides engine fan. Is it becuase of EIS or can it be something else?
When I had faulty dump on then engine fan would come on all the time.
adapation menu in EIS for either engine driven fan or elec suction fan i think is how is worded checkor change coding make sure AC module has similar settings if didital pushbutton is installed
I have given the car back to customer and told them to take it to Mercedes specialist as I have already sold me MB star and will wait for new MB start to arrive in New Year.
  W210 EIS CPU1 repair on the base of the CPU2 dump gunio 0 70 09-22-2018, 06:17 AM
Last Post: gunio
  W220 EZS Programming Tool prochipper 6 243 09-21-2018, 09:03 PM
Last Post: raffaell0
  Crafter EZS 0L01Y mileage correction koppandi.alin 4 241 09-21-2018, 09:13 AM
Last Post: Bartas222
  Crafter EIS problem - key won't turn gunio 6 224 09-21-2018, 02:17 AM
Last Post: gunio
  VITO EZS FLASH NEED cartronica 1 82 09-20-2018, 06:06 AM
