  • 9 Vote(s) - 2.89 Average
W202 Engine Runs And Stops in 2 seconds
Hello mhh members
I am Having Trouble With Mercedes W202.
Fault Code Number is p1190,p1187
Engine Runs And Immediately stops
I get high Pressure Error.
I changed Pressure Regulator Valve and Pressure Sensor
When I Start Engine there is high pressure 90-100bar,so engine stops in 2 seconds
Can anyone Help me
Thank you For attention
Das/Xentry,BMW ISTA,ODIS/VAS And Many Other Automotive Software Installation Remote Support.Just Pm Me.
under 150 bar, injektor cant open
test with other pump
Thanks given by: khomrericky , KriyenKPp
injector or high pressure pump..
If I've helped you - press Thanks and add Reputation!
Look at the reverse flow of fuel from the injector.Stretched timing chain
