Hi I have 2018 C 350E with interlocking system fault PTC heater was burned out swapped with second hand unit changed new plug and changed checked all wiring for PTC heater all looks good. Does someone has high voltage interlocking system wiring diagram and any suggestions what else to check. Also any suggestion how to check PTC heater on the bench?
Following fault codes:
P0A0C00
P0A0D00
P0A0A00
P0A0C00
P0A0D00
P0A0A00
