2,095
Thanks Given: 14574
6,536
46
Too rich can only be fuel pressure too high, fuel injectors leaking, or a bad air mass sensor.. did you reset the adaptions and drive it again to see if they settle down?
Please do that and post a pic of your adaption numbers
176
Thanks Given: 328
Thanks Received: 748 (653 Posts)
1,747
Check the intake manifold actuation flap working in order OR oxygen sensors.
Mit freundlichen Grüßen | Best Regards,
Specialist for Mercedes PKW / LKW
Modifications / Diagnosing / Programming
628
Thanks Given: 144
Thanks Received: 1725 (425 Posts)
961
47
Does the misfire occurs at idle or load? , have you done a live cylinder contribution test?
-CPC Tuning
-Renewal of FBS3 components by OBD without special tools, data restoration
-AdBlue Remaining Starts Reset/Removal
-NAFTA W906/7 Sprinter Vmax Removal
-FBS4 FDCT ISM Drive Authorization Fix
-Professional MB/BMW/Porsche/Ferrari/Maserati Immo/Coding/Programming
99
Thanks Given: 100
Thanks Received: 384 (239 Posts)
625
31
(03-01-2017, 07:04 PM)ergyssela Wrote: (03-01-2017, 06:45 PM)Rocinante Wrote: Too rich can only be fuel pressure too high, fuel injectors leaking, or a bad air mass sensor.. did you reset the adaptions and drive it again to see if they settle down?
The adaptions were reset. If needed i may check again and post the pic of the adaption figures.
P.S the car is running in Petrol and LPG. Lpg system is Vialle.
unplug lpg system.viale injectors confiuse the system.
ECU-REPAIR-KEYS-IMMO-ABRITES FULL MERCEDES-ALFA-PSA GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
Every days a schoolday
2,095
Thanks Given: 14574
6,536
46
I was just going to say, I think the LP system is messing with it..
99
Thanks Given: 100
625
31
(03-02-2017, 01:05 AM)Rocinante Wrote: I was just going to say, I think the LP system is messing with it..
i really hate viale system.the lpg injector flows direct in the original
-1
Thanks Given: 36
Thanks Received: 11 (4 Posts)
38
Thank you for all your answers ! First i am switching to Petrol and check if the problem is still there. If it is, i'll start again from the beggining.
