  • 1 Vote(s) - 1 Average
W204 C230 No Sound Harman Kardon
Hi anyone can help me on  my W204 C230 T  radio Audio 20 all works radio usb  cd but no sound i have harman kardon 7 logic Sadsmile
the harman kardon logic 7 is also missing in menu
[Image: screenshot-20190216-214528-drive-1003103...919470.jpg]
https://www.mercedes-forum.com/threads/w...ton.97784/
[Image: 20190213_210505-jpg.39589]
[Image: 20190213_185653-jpg.39591]
[Image: 20190216_155555-jpg.39590]
[Image: 209450498-w988-h480.jpg]
try to unplug the unit first for 10 minutes so it can reset itself. Unit is missing part number and software number too. That is no good..
As the MOST code is not active now it may be heat / loose component related. However I have not seen this with the PA units so far. Melco are notorious for these kind of issues which impacts MOST
Mercedes Comand/Audio region change Japan USA ECE NTG5 NTG4 NTG4.5
all my work is supported by God
Thanks given by: 123step
Disconnect battery and wait. try read again hu software. if not ok, i think, hu can't save coding most data and sound don't work. hu error hardware.
Looks like Update was activated withouth the disc's. Reset should help if HW is in takt.
Sieht aus nach aktiviertem Software update ohne update CD's. Mach mal lang reset (Akku über Nacht abklemmen) und es sollte wieder funzen….
Many thanks to all who answered so fast
Toned the battery tonight and I'll connect tomorrow morning and hope that it will work tomorrow, let me know if it works
Thanks for your info
Danke für die info
Did you change your amplifier?
Unfortunately, it did not work with the battery hate the night  without success
I have bought a second used amplifier even without success, still no sound
I have the amplifier with xentry controlled  fan ,speaker
that's all  is ok out of the speakers came sound
that can be more on the Audio 20 Radio ?
I'm at the 1.3 date at mercedes
hope that I can do it earlier mercedes will expensive invoice
what do you think what that can be
everything suddenly not more
I did not adjust or did anything else on the car
An update with the telematics cd would help if i had one
I did not find any
Have xentry 9.2014 C3 from a friend her I can test something else
Flash amplifier - problem gone Smile
Can I do the Flash  it myself or do I have to go to mercedes
Today, 12:46 AM
Author: mercomoh
Yesterday, 08:09 PM
Yesterday, 10:20 AM
Yesterday, 02:38 AM
07-16-2019, 04:12 PM
