Thanks Given: 0
Thanks Received: 0 (0 Posts)
Hello All,
i want to retrofit Distronic/ACC at my W205, 2020 C220d.
I have high beam assistent and traffic sign recognition.
Does anyone have instruction, which Camera part, Cable to use, and how to setup it at the control unit?
Thanks and Kind Regards
Patrick
120
Thanks Given: 424
Thanks Received: 624 (483 Posts)
1,359
(06-12-2026, 11:30 AM)Graml92 Wrote: Hello All,
Patrick
You may google about the difference between Distronic Pro and Distronic Plus. For Pro you may need to change your current radar and steering wheel buttons, if your EZS has the required Flex CAN
For Distronic Plus you will need many expensive parts to add and exchange and only on Plus the Stereo Camera is used
MBRetrofit Map Codes, Remote Star3 Coding
