Am I correct in assuming that if I desolder the EPROM and resolder it into a used ECU, the immobilizer will function again—provided the data set in the flash memory is identical? Where on the circuit board can I find the EPROM responsible for the immobilizer?
[email protected]
W210 220CDI Location Eprom immo ECU clone 0281010041
05-19-2026, 12:30 AM
05-19-2026, 09:25 AM
Is a genuine "immo off" actually possible, given that the Mercedes features an electronic ignition switch? I have read that this requires a modification to the starter relay. Naturally, it would be ideal if there were an alternative method—specifically, if a modification to the EEPROM alone were sufficient to ensure everything functions correctly.
05-19-2026, 10:05 AM
It's been a long time since I solved this and I don't remember the exact procedure, but if you try to flash the eeprom you will see immediately if it works.
05-19-2026, 02:17 PM
What are you trying to accomplish here? Immo off is possible in flash in these.
05-19-2026, 09:34 PM
Here are the flash and the EEPROM—perhaps someone could please help me out further?
