Hi guys, does these car need online scn programming for the ecu?
I am using 03/15 version which has the offline programming enabled. If I were to use this option, will it require any scn string at the end of process?
*a car of this model suddenly lost its *program*. When i tried to enter the cdi ecu, it only ask me to program it before able to continue. Therefore I can't check for fault or actual values.
Any help would be great!
