Dear Respected Members,
Would anyone happen to know if there is a way to do one of the following on a pre-facelift W211-
1) Disable the automatic lowering function at speeds above 68mph?
2) Independently change the ride height of the rear tires after the car has been slightly lowered with more aggressive rear tire installed? The problem is that combined with a non-flat road surface or driveway and the driver's weight, which is average and not overweight, it causes the driver side rear tire to rub. It does not do this unless the car is in Sport II or traveling above 68mph, or sitting on uneven surfaces. Is it possible to disable the highway auto lowering feature with Vedaimo? Reading DAS and WIS it indicates the car will measure and independently adjust front wheel height, however there is only one level sensor in the rear on the axle, and although the car can adjust each rear strut independently, it uses this single sensor to make adjustments to ride height in the rear. Just sitttimg in the driver side of the car with the engine running causes a noticeable drop in the driver side tire clearance. Although I may be confused, I was thinking the car would auto-level after a weight detection. I am more familiar with ABC cars. It there a better way to calibrate the ride height to prevent this? All DAS Actuations work fine and no fault codes are present.
Thanks so much.
Thanks so much.
I am not a robot. I can identify crosswalks, busses, cars, traffic lights, and mountain ranges.
