  • 21 Vote(s) - 2.57 Average
W211 E320 Cant start engine - ESP is not available
10
Yea if the sensor is completely out. Not if he is on the verge. The heater trick works then.
Before reflowing, please check angled strip between connector and where is soldered to motherboard. Pry gently with screw driver or tweezer.. Might be breaked strip.
From what I have seen this is usually caused by internal faults in the fuel computer. Having the computer motherboard reflowed may indeed correct your problem. If not then you may have to replace it.
Best of luck.
There is no "fuel computer". What is this in the first place? :confused:
Engine control unit.. fuel computer.. N3/9 N3/10.. same same.. Smile
LOL Wink
<SOLVED>
So.. today i received back engine ECU from repair and now everything working!
Unfortunately i don`t know exactly what causes problem on ECU, guy told it is his company secret, i can understand him ... but i am happy! Problem is solved.
W211 - E320
Thanks given by: Rocinante , alexjx
17
Thanks for finishing up with a conclusion. Most thread starters don't bother.
18
(11-15-2016, 09:43 PM)Raito00 Wrote: <SOLVED>
open up, see which chip has been tampered with.ItwasntmeItwasntmeItwasntme
