W211 Eis mcu data corrupted
Hi I need some help it's first time have this situation and need some advice ,I have a w211 with eis problem so I dismantle eis to backup data and clone on other eis but the mcu data is corrupted ....What need now to start the car ?
Need virgin yard eis and do initial startup with xentry ? Need online scn ?
Then learn new key ?
A 211 545 23 08
backup.rar
10
58.94 KB
If I help you please push the [Image: postbit_thx.gif] and [Image: postbit_reputation.gif] buttons .
what programmer did you use?
R270 and orange 5 = same dumps .
I have from scrap yard Eis with key, I can renew ecu and use elv emulator ?
Ecu is CR4.12 if renew ecu I just need xentry and initial start up ? no need online scn ?
have you got tools to read ssid from key ? or cluster? what mcu you got in esl? can you read it?
I never seen eeprom damaged like that try read it again as 4L40K
New!!!Clone of med17.5.21,me17.5.24,med17.5.25,EDC17CP56,EDC17CP64 immo off/immo rebuild on VAG ecu's Modus/Clio/Megane steering column repair/virginising Merc EIS/EZS/ECU/Key generation ...and many more.
Thanks given by: bawarek
Try read with Xprog
As Keller said you need to find the original ssid or you will be in big trouble.
Thanks for your advice guys , for key I have nothing to read it but, for dash ssid is in eeprom ?
If I post dump someone can give me ssid ?
FVDI can read ssid ?
I just ordered a CGDI but need to wait 10days or so to arrive .
What about esl?
ESL was bdm locked on first time orange 5, r270 didn't read it just wait.
So I use sec then boot on orange 5 and the result is the dumps above .
Just read same ESL with same 1L59W with R270 and read it just fine.
If I select 4L40K it detect is not ok and tell me is 1L59W.
I will read with xprog to see.
I see carprog can give me SSID.
But if I 0km the dash and adapt to esl it will show km so why I need the ssid ?
Or in 211 it's not working to 0 km and adapt with xentry?
Xentry can read ssid if I connect dash on bench ?
1 hour ago
12-09-2019, 01:34 PM
Volvo
12-08-2019, 04:25 PM
12-07-2019, 05:38 PM
12-06-2019, 01:30 AM
