  • 13 Vote(s) - 2.69 Average
W211 SAM DRIVER
I will ask some about sam driver side.. I want disable the status check off sbc on the sam module. I know that pin 4 on sbc go to sam module for system check. When ignition is not on or no key in ezs, when i pull out the cable from sbc give the ic red warning.. This error come from sam module. Can i disable this warning with devloper mode in the sam module driver side? I see lot off acctuations but i dont know witch..
W211 2003
Rgs
Umka
Disconnect both batteries...? I hope you are doing some repair/maintenance, and thus want disable it. You won't need batteries then.
(03-16-2016, 06:30 PM)mersum1es Wrote: Disconnect both batteries...? I hope you are doing some repair/maintenance, and thus want disable it. You won't need batteries then.
Hi i need no for repair i want disable the warning on ic
Just curious; Why you want disconnect SBC at first place?
(03-16-2016, 11:23 PM)mersum1es Wrote: Just curious; Why you want disconnect SBC at first place?
I will Build an other abs al wil work but when ignition is off it will warn red when ignition on with other abs it wil go ... The sam can not see that sbc is active....
There is an option Elektrohydraulische Bremse aus/ein in KI, have you tried what is does?
I believe it is so important safety message that you cant disable it...? Just a thought, can you make variantcoding for system that model year of the car would be 2006 and since there is no SBC installed? Fake facelift modelling may cause lotsa other troubles, and not sure ECU can handle it... there is no option for SBC yes/no in ZGW Wink
(03-18-2016, 02:27 PM)mersum1es Wrote: There is an option Elektrohydraulische Bremse aus/ein in KI, have you tried what is does?
Hi yes i know ther is no option in ZGW... the warnig come up when i have no key instert. the cars from 2006 with abr have also a status chek to the driver side sam. who now an electiric schma to overlap this warning. i know it is in the sam.b i have also try the elektrohtydaulische bremse to aus.. but nothing cange....
rgs
umka
UPDATE....
Another Sam module from facelift and i have no erors!!!!!!!Cheer2
Thanks given by: Rocinante
