  • 17 Vote(s) - 2.65 Average
W211 Speedometer Problem
Hi Everyone,
I found a problem similar with attached picture.
The digital show the wrong speed's units.
When set to km/h, it shows the mph value with km/h units. When set to mph, it shows the km/h value but with mph units.
Can someone help to solve this problem. Thanks
Thanks given by: naseem__amg
Instrument cluster need to reset I think
Have tried using DAS, no luck 1087 ......
That is normal, you are using tourist mode.
Thanks given by: daxxer
What do you mean using tourist mode?
Change it in vediamo
Mercedes BENZ CODING 223/254/214/206 STAR3 ECUS
MERCEDES BENZ CODING
JLR CODING AND PROGRAMING
Region Conversion & MAP PIN: NTG 4.5/4.7/5/5s1/5.5/6/7/GEN20x
I am a newbie guys...
can you give me step by step tutorial please..
