  • 9 Vote(s) - 3.44 Average
W211 ZGS coding.
Customer has a W211 and can't communicate with the original ZGS. So I opened it up and read the 9s12DT256 then I wrote the bin file to a new ZGS. My question is what device is the Variant coding stored. When I put it back in the vehicle and hook up Xentry I have no codes but the variant coding is unknown. Also I have a bunch of i, in modules but no codes in those modules. I believe it's because it doesn't know the variant coding. The vin is in the module, mileage. Thanks for any and all that will help
Sent from my SAMSUNG-SM-G870A using Tapatalk
You are doing it wrong: with correct diagnostics software and hardware it is easy to renew used unit and code it acordingly to the cars equipment.
"i" you have because there are stored faults which need attention. Again: with correct diagnostics software and hardware you would be bale to see them all......
This is a new module. I understand what u are saying. But I wasn't able to read the original so that is the reason for reading the device. What hard ware and software do I need to be using. Vadiamo
I was using xentry DAS
DAS is enough for it....
Ok, I see no fault codes in the modules with ,i, out to the side. Does it need scn coding
I don't work with MB much learning them. Mostly US and Asian vehicles
open menu under ACTUAL FAULTS (menu under this one)
Ok thanks, I will check. If I can not communicate with the original do I need to go online to code it
