Thanks Given: 394
Thanks Received: 331 (133 Posts)
1,107
493
Hello,i have problem with w211 someone help me to activate system where by when i hold key button lock/unlock the car door mirror are closing or opening ,please i tried to set in cgw convenience to close automaticaly but still not work
26
Thanks Given: 198
Thanks Received: 87 (44 Posts)
342
69
you dont need to hold. the mirror closing is activating by the dash .if you looking for comfort windows closing i thin only the cars with ir on the door handing have it
104
Thanks Given: 135
Thanks Received: 603 (278 Posts)
730
122
This only works via IR sensor in driver door. You have to hold the key in direction driver door handle. I have to say, very very very often, this ir sensor is damaged !! If you have DAS, you can check it in actual values from driver door electronic module..
