Thanks Given: 112
Thanks Received: 32 (27 Posts)
650
265
Hi, I have a problem with the car E Class W211 2.7 CDI.
The problem is something that still takes a current I after two days the battery is completely discharged. When you turn off the car all the time something gets a current of about 5A. I also noticed that it can not connect the scan tool to the control module battery.
Is he might be corrupted? Or maybe you know some typical symptoms of this model, which cause these symptoms?
How can I check the battery control module?
thank you
Kris
0
Thanks Given: 3
Thanks Received: 13 (9 Posts)
15
0
The Teleaid ECU can turn on intermittently and cause the drain. It can be difficult to diagnosis.
If you put a fully charged battery in the vehicle and do not road test it, the battery will survive for a week or more. If you install a fully charged battery and road test it, it will be dead the next day or two at the latest.
Disconnect the Teleaid and code it out. Reroute the MOST too.
2,095
Thanks Given: 14574
6,536
46
(02-18-2017, 03:02 PM)krzysdro Wrote: Hi, I have a problem with the car E Class W211 2.7 CDI.
thank you
Kris
If you have seats with memory, unplug both front seat control units and see if it fixes the problem.. its very common that this cause a 2.5amp draw on each one..
Thanks Given: 82
Thanks Received: 26 (17 Posts)
103
26
Do you have an Electrical engine heater? if yes, put an AMP meter on the cable from starter to heater.
there known for taking power in standby
0
Thanks Given: 3
15
0
Does your car have Teleaid? If it does, unplug it. Drive it a distance and shut the vehicle off. See if the draw comes back. If it does not, that's probably the cause. Then you need to change the MOST optic lines so the sound system works again. Probably code the Teleaid out of the system when you are done.
