  • 4 Vote(s) - 3 Average
W212 gearbox change
Hi everybody,
ive needed to change gearbox on W212 E220. The donor gearbox (same number 722.996) comes from an W204. It does not respond to the selector commands. What needs to be done to get the gearbox working?
u got ISM or EWM?
SPECIAL FILES DATABASE FOR VEDIAMO/DTS MONACO
ADBLUE, DPF, CAT, VMAX OFF
VIM 205 213 222
(05-30-2018, 01:38 AM)tirex2k Wrote: u got ISM or EWM?
Gearbox has an mechanic lock and no module from outside the box so should be EWM i think. Am i right? The old and the donor gearbox are the same Axxxx9002 number matches and 722.996 also.
i think you need abrites
You need to renew gearbox plate with a avdi, fvdi, mi or other tool’s. And after that relearn new gearbox to w212
Thanks given by: KriyenKPp
Hello Friend
you need to renew the electronic board 722.9
with abrites, vvdi, diagspeed or others that can
do the function
2nd step program scn coding or vdiamo
I can do for you via teamvier the scn and programming
If you have updated star diagnosis
Trouble is i dont have no abrites/vvdi hardware. So for me the fastest solution is to clean the old plate/valves and swap the plate for the old one.Sadsmile
Yes, If your old plate is ok then this will work just fine! If you got monaco / vediamo we can also do it.
If my post help you then please thanks and Rep will make me feel motivated.
Mercedes Comand Radio Audio Region Change Japan USA ECE NTG5 NTG4 NTG4.5
4 hours ago
11-19-2019, 12:48 PM
11-18-2019, 07:47 PM
11-13-2019, 03:59 AM
