W218 CLS dead dash
does this type dash have some common faults?
Power is ok and can lines are too.
But dash is completely dead.
Thanks in advance!
It just makes me feel good Thankyou
Thanks given by: Kakabasa
#2
(10-11-2018, 06:03 PM)Raints Wrote: Hi,
Thanks in advance!
test to take off battery cables
Dash is taken out and put it back still dead.
Positive 30 and 15 are ok and ground too.
Can is also ok
Check the eeprom, also check if you can maybe communicate with it over vediamo/xentry
  mercedes CLS 722.9 cff need gutmann 1 104 10-11-2018, 08:49 PM
Last Post: Sammous
Mercedes Benz Puddle light cls w219 coding Xentry fjanssen 1 259 10-03-2018, 02:25 AM
Last Post: fjanssen
Mercedes Benz Mercedes CLS W219 retrofit led taillights vincha7 1 1,393 09-25-2018, 03:37 PM
Last Post: georgeliro
Mercedes Benz w218 electrical steering reevacenter 3 330 09-20-2018, 04:35 AM
Last Post: nothing
  retrofit w218 headlight erion 1 426 09-11-2018, 07:44 PM
Last Post: rashid
