  • 4 Vote(s) - 3 Average
W219 CAN BUS problem
Hello!!!
My w219 is having problem with CAN BUS.
fault with can communication with A1(instrument cluster) and N93(central gateway control)
the driver-side window lifter doesnt work and headlights not working
What is happening please help!!!!
Dashboard completely still
MB Star2 Star3 Remote coding Anti Theft pin Map pin Renew FBS3 without special tool https://linktr.ee/SebaTechGeorgia
(03-09-2017, 11:42 AM)gio777 Wrote: Dashboard completely still
Nice try....
Kolo
Unplug the instrument cluster and see if the problem goes away..
Also the Central gateways get condensation dripped on them and for corrosion inside. If its just started happening, sometimes you can open it and clean it, then seal the connectors with dielectric grease..
