  • 23 Vote(s) - 3.26 Average
W220 ESM Keyless go no drive authorization
Hello friends. I really need your help again. I just purchase 05 w220 keyless go car, without a key. I purchase new key from dealer. I bring home and key turns but no crank. Shifter will not unlock. Sds tells me no drive authorization in ESM. What options do I have. Dealer said 800$ for new ESM but need programming 400$. Can I buy ESM new and program myself and keyless go will work?
hello friends, any idea what i can do about this? i want to move the car. how can i program other second hand ESM
Did you buy the key pre-programmed?
There are two flavours of key available to purchase.
In the UK you need to prove identity and ownership of the vehicle before MB will order a new key.
I ordered a pre-programmed key and when it arrived MB removed all the missing keys from the car's memory and only left the two keys I had.
In DAS/Xentry you can add or remove keys but to program a new one you need a green workshop key.
There are aftermarket rigs that can program keys (someone on here has shown his working) but I do not know if it will do keyless go.
Unfortunately that is as far as my knowledge goes in programming keys.
