  • 16 Vote(s) - 2.81 Average
W221 DRL change
I have a 2007 S550 (w221). When the daytime running lamps are enabled, the headlights are constantly on. The newer W221 with the LED lights, when DRL is on, only the LED "fog lights" are on. I'm wondering if it's possible to reprogram the car with DAS or Vediamo in order for my for lights to act as DRL and the headlights to only go on when it's dark?
2007 221 has no DRL. Headlights act as daytime lamps.
  • SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
  • HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
Hi there, and yes had the same problem so I retro fitted some DRL`s in the bottom grill and wired from the engine bay fuse box on the live ignition side. Ignition ON they are on. Bought them off E-Bay and wired them in with a fused line just in case. Neat and tidy and at very little cost and been working for the last 3 years. Make sure you check the height and distance is within standards (googled for this information) when attaching them.
Self enlightenment is a pure pleasure through a Mercedes
