  • 2 Vote(s) - 3.5 Average
WHAT voltage use CAN BUS?
Hi All.
I need to know what voltage is on can h and can l on OBD connector and instrument cluster for VW /SKODA/AUDI?
I think for obd use 12v and for instrument cluster use 5v!
Many thanks.
there are messages passing through can h and can l and if you measure the voltage you have to use an oscilloscope, you will see a voltage around 2.5 v
If I helped you please press thanks and rep
Thank youNerd
Thanks given by: KriyenKPp , HestonDiag , tao13
#3
on obd and instrument cluster too?
many thanks for your answer
https://en.wikipedia.org/wiki/CAN_bus
Thanks given by: HestonDiag
#5
(07-19-2018, 05:14 AM)tao13 Wrote: Hi All.
Many thanks.
[Image: can-voltage-levels.jpg]
...i think this image better for understud)
Thanks given by: diagnostix , KriyenKPp , HestonDiag , tao13 , chcp
#6
(07-19-2018, 05:24 AM)tao13 Wrote: on obd and instrument cluster too?
press the magic buttons when someone helps you, not say itFing32
Thanks given by: diagnostix , HestonDiag , svvag2000
  Skoda Superb 2017 change charge voltage kozik20l 4 112 07-24-2018, 10:17 PM
Last Post: kozik20l
Audi High-voltage air conditioning compressor dubredzone 2 71 03-18-2018, 01:29 PM
Last Post: dubredzone
Audi CAN-BUS Check Roberto 0 89 01-28-2018, 11:09 PM
Last Post: Roberto
Audi Possible to to use a 4g usb modem on a 3g+ mmi Segadora 4 97 01-16-2018, 02:46 PM
Last Post: sweegie
VW Mk4 golf gti can bus problem solved RafiCar 2 484 11-09-2017, 06:55 PM
Last Post: KriyenKPp
