  • 37 Vote(s) - 3.16 Average
WOW! update 5.00.3 to 5.00.4 ENG + any language now...
10
hi,
i made the update -> all flawless
but now my wuert is in english -> any chance to turn it back to german?
br
Thanks given by: Chri1911 , mileage , batko
11
Is there a way to use Delphi 213.3.3 in Delphi AND THIS update with WOW without re-flashing VCI every time I want to swap from one Program to the other?
Copy firmware folder form Delphi/Autocom to WOW (wow\ac_diagnosis_module\firmware) and start firmwareupdate in WOW
Thanks given by: r66r66 , miroslav
13
OK have copied both supplied temp folders to Wow install folder, start prog, nothing still remains and works as 5.003. NO update connected or not connected to VCI which is Delphi DS150e new.
Any thoughts would be appreciated.
Running 1331 firmware by the way from Delphi/Autocom
(05-19-2014, 11:51 PM)carl13 Wrote: Hi,
Copy the contents of both folders to the folders of the same name in Wow
Good luck.
Good luck.
OK, running Windows 8.1,
Have installed WOW - SdCard/Virtual Disk Drive/Wow.
NEVER had the Two Temp Folders in above install Directory; so just Pasted the upgrade temp_xxx folders into the install folder.
No Other references to Wow on the C: Drive in Program Files or Program Data etc
Tried every way I know to get it to update but it wont have it.
C
Open file tmp_basics and copy contents into
C:\Users\Public\wow\tmp_basics
then open file tmp_modules and copy contents into
C:\Users\Public\wow\tmp_modules
then start Wow and it will update itself wile starting and when it does start it will be Wow 5.00.4.
Good luck.
(06-07-2014, 01:10 AM)emifive Wrote: Open file tmp_basics and copy contents into
Good luck.
Cracked it now;
Had to Delete Wow folder from sd card virtual drive,
Re install in default Public location.
Updated ok.
Updated Firmware.
Moved entire wow folder to sd card.
Runs fine.
Thanks, Carl
Thanks.
Hello all i have downloaded 3 times, but when i try to open ,it tells me ,its not a valid RaR file ,I am using Win zip pro 1.4
OOPS Just downloaded Win Rar and all ok , never knew Win Zip was different ,all working many thanks
08-02-2020, 09:28 PM
08-01-2020, 01:17 AM
VW
07-19-2020, 02:06 AM
07-18-2020, 05:43 PM
06-27-2020, 07:45 PM
