What programmer for eeprom read/write?
Hi! As the title says I am unsure on what type of eeprom reader I need. I need to read and write eeprom of engine ecu sprinter w903 for cr2 immo emulator, I would also like to be able to virginize w209 cluster. What programmer is able to do this? Is ezp2019+ good enough for this job?
so you want to read both
Engine ECU w903
and W209 Cluster ?
Xstages Motorsports
Tuning | Performance
(03-25-2024, 03:49 AM)Wiktorix2 Wrote: Hi! As the title says I am unsure on what type of eeprom reader I need. I need to read and write eeprom of engine ecu sprinter w903 for cr2 immo emulator, I would also like to be able to virginize w209 cluster. What programmer is able to do this? Is ezp2019+ good enough for this job?
It would be usefull if you gave the eeprom number that you want to read/write.
You could easily use a $2 CH341A for most types.
Regards.
Panasonic CF-H2, CF-20 (Win7/10, Xentry-DAS, Vediamo, DTS)
Open port 2.0, VCXSE, C3. (Retired newbie, still learning).
04-16-2026, 06:42 PM
01-26-2026, 06:16 AM
11-22-2025, 11:06 PM
