37
Thanks Given: 266
Thanks Received: 173 (117 Posts)
415
68
03-26-2019, 01:45 AM
(This post was last modified: 03-27-2019, 06:45 PM by webmaster.)
Hi all MHH member,
I bought new axle-hub dyno from Dynomite (USA).
Install it but can't set the correct drive-line lost percent.
I sent the log to Dynomite helpdesk but they ask it all right. "The parameters are good."
I get all time about 20% lower torque and power.
If I set the 10% drive-line lost and 10% axle-hub lost the value is about good.
THIS SET ISN'T EXACT!
I would like set to the automatic calibration it all time!
Can everybody help me how can set the DYNO-MAX PRO software?
THANKS!
37
Thanks Given: 266
415
68
03-26-2019, 10:39 AM
(This post was last modified: 03-26-2019, 10:40 AM by szenti71.)
Here is the picture from software.
1,152
Thanks Given: 105
Thanks Received: 1922 (1529 Posts)
2,655
41
Try increasing inertia value
File Service
Stage 1 - 3 , MANUAL DPF , EGR , Adblue, DTC
Authorized Magicmotosport, Autotuner, Alientech, EVC Distributor
37
Thanks Given: 266
415
68
I select the inertia value from the type of the list in the software.
Have a nice day!
35
Thanks Given: 47
Thanks Received: 214 (129 Posts)
340
34
Main problem is that in US all dyno measuring is allways WHP and in europe engine power. For good solid engine power you need to fix your own driveline lost maps.
Scania EMS10 scr/dpf delete ready! International S13 Delete ready!
*CAT scr&dpf deletes* *Volvo US truck deletes* *Scania S8 & EMD1 deletes*
*Scania S8 VGT delete*
37
Thanks Given: 266
415
68
03-26-2019, 04:43 PM
(This post was last modified: 03-27-2019, 10:27 AM by szenti71.)
Thank you for answer Zeder & Sape! ;-)
How can I make Drive-line power lost map?
That is mean all measurementit it will isn't exact? I'll get only about value?
Have a nice day!
37
Thanks Given: 266
415
68
I set 14% lost power but 3 -8% lower the power.
Any idea?
Have a nice day for all!
1,152
Thanks Given: 105
2,655
41
You need to ask your support to help you with settings measuring power at engine not power at wheels
File Service
