  • 1 Vote(s) - 1 Average
WinOLS Stage 1/2 files
Hi everyone,
I have a question about WinOLS tuning databases.
Are the Stage 1 and Stage 2 files usually ready to flash directly to the ECU after matching the original file, or do you need to modify and finish the WinOLS projects myself?
I’m considering buying a large tuning database and would like to understand how it works.
Thanks!
hello
first databasse bought in web all or most 99% are bad in natural time and for a garage for long time coperation (with client)
secend you can write directly but (chance ) can car start can ecu bricked can the car go limp mode after 3 day can the engnie bricked and the last one can the file from database working good in (3%)
use it and warning
Thanks given by: Domenik85
(Today, 02:56 AM)MHH-Solution Wrote: hello
use it and warning
Thanks for the information.  Tup
Tehnicly you can use it to transfer tune via winols function if engine and ecu are the same. Is that the best option, not really, you dont know files you are purchasing. But everybody chooeses his path .
https://onebyte.com.co/ - Free trial like winols editor with auto stage1 and dpf, egr, adblue, decat Ethanol grades, Stage 2 for some ecus, gerbox remaps 1-4 Stage, swirl off functions for supported ecu per sw.
Supported list grow every day!
cannot answer your question because each car is different, can you match a file 100% and then flash the mods straight away, yes
do you think that matching a file 100% will always happen, no, esp with the likes of BMW / vag med9.1 etc etc
so you need good winols experience to be able to transfer the changes from one project to another, because looking at some tuners work on here they dont have that
good tuning is not free, free tuning is not good  Wink
i run garage but file service possible
Stage1/2 EGR DPF Adblue Swirl DTC etc
Users browsing this thread: Kevinstylee, realtekprofi, 1 Guest(s)
