nimrooz
Location OfflineJunior Member
0
Thanks Given: 14
Thanks Received: 5 (4 Posts)
26
Hi guys, trying to native install 01.2014, saves key in star utilities, then mount the 1st dvd starting installation, then it checks for genuine , and then starkeycenter appears with message of non valid xentry key.
Then i see that the appid have changed and hardware id has changed also.
But it doesnt recognize the keys coming out from my keygen xentry developer from this forum.
Appid> 253
HW ID> 690936CC4251
Have tryed to use the dates> 20121212 to 20170101
Das and Wis keys are fine though...
Maybe you guys have a better keygen...
nimrooz
0
Thanks Given: 14
26
LSKCE8MJNSP8Q4EBBVT9B75CG38JGV9V4FAQW372W49PS7Q2XTMEVC2BL4CV3BW8RWXSY2U2LPAUKETB3XEK5LM2HYHBJGLHJMW64HUCCUEJ7DKP8BNN7Y9LKSTLQB9ZX6
[/quote]
Hi, tryed your key, unfornatly that didnt work either, thanks anyway though.
The error message i get when trying to install is>
No valid startkey detected, errorcode SC00003E
Any ideas anyone
jpargt
Thanks Given: 52
Thanks Received: 12 (5 Posts)
38
10
04-24-2014, 12:04 AM
(This post was last modified: 04-24-2014, 12:07 AM by jpargt.)
didn't accept my key at first then it worked when I changed it to 2014 -2020
What is the date on your computer?
2,095
Thanks Given: 14574
6,536
46
I always use 3 year keys.. so 20140101 to 20170101
3,178
Thanks Given: 7612
1,696
53
if you use wbemtest, you have to restore the manufacturer and model to default..
if already done, try to delete lic_key_2.dat in
c:\documents and settings\all users\application data\licdir\lic_key_2.dat
and entry the xentry key again.
hope this helps
