  • 48 Vote(s) - 2.94 Average
XENTRY/DAS how to enable prototyp 212,207 and other ?
10
This worked for me on my 2014/07 DAS. I just ran the .exe from within my vitual machine, very useful. Thanks and reputation given.
cheers,
Andy
(05-18-2014, 12:59 AM)Fouad Wrote: Tested at DAS 2014 Fing32
[Image: 2zp18w4.jpg]
[Image: 24ys679.jpg]
[Image: 28mgs5s.jpg]
Hello, I want to know how to install these files, I have version Xentry 12.2014; thank you
(07-15-2015, 01:43 PM)mercomoh Wrote: Hello, I want to know how to install these files, I have version Xentry 12.2014; thank you
Did you try "copy/paste with file manager"?
Thanks given by: daxxer , mercomoh , newyoga39
13
Thank you for your answer, I do not know;
on which partition?
In what cases? thank you
I have installed xentry 12.2014 too, in with folder must put the files?
Have you solved the problem?
I want to update my instrument cluster. But in DAS is no w204.
In my old 2012 version was the w204
If you want to have W204 and W204 prototype on 12.2014 I believe it is best to run the prototype fix from Fouad (this thread) first and then the W204 fix from this thread: http://mhhauto.com/Thread-Add-W204-in-later-DAS
16
I installed the fix from Fouad, prototype are enable. But no w204. Waiting for the password from this other thread...
The package from fouad does not working on DAS 12/2015, in which path i can copy the files manually?
I have windows 7 x64
edit: problem solved Fing32
how to enable this menu
Thanks given by: moftah
