  • 13 Vote(s) - 3.31 Average
XENTRY Kit2 User Guide
As stated in header this is a user guide for xentry connect.
  If you find it useful rep and (or) thanks are welcome.
So, Connect is the same and Tab 2 is the only new device?
if you compare 2 kits in those xentry connect is the same. Tab itself you can call remote control device for xentry connect as xentry connect is independent computer by itself where sd cponnect to compare is diagnostic interface only (do not mix with fake Chinese xentry connects as these are just sd connect in Xentry connect alike housing). Xentry connect can work independently with no external computer attached localy - for example you need remote support from MB special tech - you connect to the car, break your session and remote assist guy takes it over (I mean head itself) .
Thanks given by: A2ua
Yes, I know
I work with Xentry KitWink
a... ok
