Thanks Given: 85
Thanks Received: 25 (16 Posts)
102
24
Hello Friends,
i have problem with my Xentry computer work all perfect but every time after install vediamo 5.0.0.6 xentry stop working !
on initialization i have INTERNAL FAULT 3.822 - 3.15
anyone can help me with this issue ?
regards
2,095
Thanks Given: 14574
6,536
46
That sounds more like an Xentry problem and nothing to do with Vediamo...
Make sure your cal.sli is the proper fixed one in the llist folder..
Thanks Given: 85
102
24
but it is second time i work with xentry all good but after i install vediamo xentry not work
i test on second computer this same problem after instalation
before work good
72
Thanks Given: 706
Thanks Received: 583 (231 Posts)
336
Uninstall Vediamo & see if Xentry will work. If it does try installing 0.5 vediamo & see if it works
Art
Thanks Given: 85
102
24
After remove Vediamo software still xentry have fault, ( xentry, make connect with car i can see car battery voltage and also vin number but 20 sec after i have this fault and xentry is closed
72
Thanks Given: 706
336
Then follow Rocinante's advice
Art
645
Thanks Given: 139
Thanks Received: 1977 (493 Posts)
1,303
192
if it's china clone... i might know that
the fault usually because the current computer time is not set correctly according to DAS/XENTRY version.
you should set the computer to 3 month later than DAS/XENTRY version. Fro example, the xentry version is 2014.12, so you have to set the current computer time to 3 month later: 2015.3.
