  • 17 Vote(s) - 2.82 Average
Xentry 2012 only install on Dell D630?
I use Sdconnect(C4) interface. Can I install Xentry 2012 on other Laptop?.
What is laptop model?
Show me please!
Dell D630 (and IBM T30) are diagnosis tool sellers' favourites in order to keep the number of supported laptop models low. You can use pretty much any modern Windows XP SP3 laptop with the SDconnect tool, specifically because it does not need the serial port.
Thanks given by: webmaster , tamdogau
(12-30-2012, 07:29 AM)tamdogau Wrote: Xentry 2012 only install on Dell D630?
Show me please!
you can install on any laptop you wish m8 049
ideal would be to use a laptop with serial port but as you say you have SDconnect mux ,you are not restricted by serial port , just remember to be a laptop who can accept XP SP3 to be the OS,,cause the newest are developed for W7 or W8 , and the best OS for MB SD still remain XP
Peoples use to install in D630 cause of his performance and size,cause to use a large size laptop in a garage and through a car is not so comfortableWink
Good luck Beer
I recommend Dell E6410 ATG For all Workshops.
I have one, Its very fast, reliable and business Laptop as well Tup
[Image: Dell+Latitude+E6410+ATG+Durable+laptop+w...th+3.0.jpg]
Also I recommend Dell E6410 E Legacy extender ( Mini Docking station) which fits on this Model. Pc
[Image: elegacy.jpg]
Best regards.
Tup
[Image: mhhsig.gif]
MB Navi, Theft Codes & much more..
I use the panasonic toughbook cf-74 with integrated serial port and clone C3 mux .. it works perfectly! is a rugged-PC with touch screen and has a carrying handle ... You can also use the toughbook cf-18 has the same features but is tablet!
T30 can not work any more with the versions 2012, it goes like a turtle.
111
(01-24-2013, 03:42 AM)pariscy Wrote: T30 can not work any more with the versions 2012, it goes like a turtle.
There was this story about a turtle and a rabbit if you remember... Smile
We have the same view about a proper laptop for this diagnosis tool but to be honest, nothing prevents a T30 being used with 2012 versions.
I once helped a workshop nearby to get their tool up and running and suggested them to purchase a modern laptop but they insisted on a cheap T30. Now after a few years I updated their SW to 11/2012 and the T30 still keeps serving this workshop.
1 GB of RAM or more and a decent CPU is enough to make it usable, not the best option available but it does work. Members here may only have the T30 and we should not scare them off from trying later releases.
Thanks given by: ToMiBoY
I have SD-11-2012 on a Dell D830 installed.
Works fine! Wink
Is there DAS option available for the 11-2012 Xentry? or will working only from the xentry icon.
I have problem on the 204 cars from Xentry.
05-20-2020, 05:30 PM
05-13-2020, 08:48 PM
VW
05-12-2020, 10:49 AM
05-01-2020, 05:38 AM
04-24-2020, 06:47 AM
