  • 4 Vote(s) - 2.75 Average
Xentry 2016 07 He continues to lose the license of Xentry and Ewa
Hello to all!!! I installed Xentry 2016 07
I did not find anything in the Forum. Only XP
It will be because I use the translator.
Is there a solution?
Where do I find the folder, Licdir where you save xentry das licenses
Do you tell me the right path? Thank you.
[font="MHH Font", Calibri, sans-serif]Se ti ho aiutato non dimenticare Grazie + Reputazione[/font]: stretta di mano:
[quote='pijey' pid='994579' dateline='1498992482']
[/quo
Have the Lic folder trick?
Thanks given by: pijey
(07-02-2017, 04:51 PM)momosam Wrote: [quote='pijey' pid='994579' dateline='1498992482']
[/quo
NO
Do This
copy C:\Documents and Settings\All Users\Application Data\LicDir\lic_key_2.dat to the desktop.. rename it to lic_key_2.x4711.. copy it back into the directory. make the lic_key_2.dat file NOT read only.. make the lic_key_2.x4711 file READ ONLY
Thanks given by: Rocinante , maxeugen1 , Pluto , tjames48
Version 2016.07 means that your system is Win 7+,LicDir folder is in different path from WinXP.If i understood you well,you want the correct path for your system and not for XP.If it is that,then the correct path for the LicDir folder is C:/ProgramData but,i don't know if it will solve your problem.I try different thing.This is what i do to prevent StartKeyCenter from losing keys.
Go to C:\Program Files (x86)\Mercedes-Benz\AppServ (if x64 bit)
or C:\Program Files\Mercedes-Benz\AppServ (if x32 bit)
In that folder,there are 2 files,edit each one as below:
Find the parameter with the name=ZBUS
URL=https://aftersales.i.daimler.com
and change it to :
Name=ZBUS
URL=https://localhost
That will make your SKC to stop losing keys.
Thanks given by: pijey , Fouad , workshop369 , apple , Stelaras
Hi, and thanks for the info
Tonight I do the test.
Thank you
Excuse my English
05-26-2021, 12:52 PM
05-23-2021, 09:41 PM
05-15-2021, 02:27 PM
05-14-2021, 04:25 PM
05-06-2021, 10:35 PM
