  • 8 Vote(s) - 2.75 Average
Xentry 2016.09 cannot connect with r class
Hi ppl.
I got a car today i couldn't acces with my star tester.
its a R class (251). Nothing happens, i guess it stops because of timeout. Am i missing something in xentry database / software etc?
I have no problem reading other cars.
Thank you all
Maybe something wrong with car???
05/2016 xdos here
unable to access the ECU of R-class.(limited diagnosis range)
03/2015 xentry works.
i am still waiting for help. Sad
It is possible to communicate with car through Delphi tester, so i guess at least the "mercedes" tester should be able to communicate with the car also.
Tested with 12/16 xentry(with sdconnect 5),it works.
Bad version of 05/16?
I have a similar problem with my car (W219 CLS). It is unable to read the vin number, the production date, the ignition status. I have never had a problem with any other car (W210, W211, W203, W221).
Mercedes could communicate with the car just fine. It most certainly is not the software either because everything was checked by Yudi, so Xentry seems to work just fine. Could there be a problem with the mux? Maybe some cars are very sensitive with the timing on the bus port or something? So strange that the issue only occurs on one single car
(02-16-2017, 05:22 PM)blackseries Wrote: I have a similar problem with my car (W219 CLS). It is unable to read the vin number, the production date, the ignition status. I have never had a problem with any other car (W210, W211, W203, W221).
using the same MUX on a 03/15 and it works well with it.3939
i am on dead end, now in discussion with the office to purchase dietrih package.
Do you think it has to do with the software version of Xentry?
So maybe it is software related then, let me sum up which versions caused problems on which cars:
2016.09
- R class (251)
- CLS class (219)
2016.05
- R class (251)
I do not understand why these versions cause issues only with some cars but not with others.
(02-16-2017, 10:05 PM)blackseries Wrote: Do you think it has to do with the software version of Xentry?
2016.09
- R class (251)
- CLS class (219)
2016.05
- R class (251)
Could it be because of offline patching? I cannot tell for sure since i haven't tried before/after. Maybe i will just have to update to newest version, maybe it will fix problems. can any1 tell if r251 can connect with latest xentry?
