  • 21 Vote(s) - 3.19 Average
Xentry Internal error (3.18)-3.247
I tried searching and was unsuccessful in finding anything on this. I'm running 12-2015 XDOS on DELL E5500. Was getting tired of having to put a new key in everytime I opened Xentry since my laptop is online for programming. I tried Rocinante's lic_key_2.x4711 trick and now I get this error. I tried undoing the "fix" and just going back to the way I used it before and I get the same error essentially whenever I try connecting to a vehicle. Any thoughts? Thanks in advance for the help
hm...could it possibly be the ticked "read only" properties?
the only thing i changed when i met this error was to untick the "read only" properties.
i am not very sure if it works for you tho.
Thanks given by: benztech823 , BillyBoy1234567
(08-04-2016, 04:55 PM)alexjx Wrote: hm...could it possibly be the ticked "read only" properties?
Had yet to try that. Just did and got pretty much the same error. Instead of 3.18-3.247 i got 3.18-3.248. Thanks for the suggestion
Mate, how big its your file lic_key_2.dat?? " =0 bytes " ???!!!
Xentry&DTS with eCOM&VCI support
DTS 9.04.16 SUPPORT
(08-05-2016, 11:15 AM)carlo Wrote: Mate, how big its your file lic_key_2.dat?? " =0 bytes " ???!!!
oh wow, i'll have to check that. i ended up running another hard drive that i had a back up on till this is figured out. i'll look at the file this weekend and try to see why. thanks
