  • 2 Vote(s) - 5 Average
Xentry OpenShell + Daimler Truck - Acronis image with Vediamo Monaco WIS EPC...
19
(03-21-2026, 01:36 AM)davito1 Wrote:
(03-18-2026, 12:27 PM)Aleksey-MS Wrote:
(03-18-2026, 12:22 PM)davito1 Wrote:
(03-18-2026, 03:36 AM)Aleksey-MS Wrote:
(03-17-2026, 11:35 PM)davito1 Wrote: xentry 09/23 asks me for username and password, what am I doing wrong?
Helps to update the file C:\ProgramData\Mercedes-Benz\config\XD_DT\offline.properties
What do I have to modify in that file?
You can try updating it. It helps for Xentry 09.2023, 03.2024, 09.2024.
This file.
Hello, will my sd c4 c5 xentry 0923 be blocked?
it's solved
Hi, these devices won't freeze up; they're all suitable for use.
Thanks for ur Job!
I already have version 2025 installed, but does anyone know how I can make it work with my SD Connect C4? Thanks a lot.!
(03-25-2026, 11:40 PM)Dariobcm Wrote: Thanks for ur Job!
Hi, yes, I can do that for you. I have the version you need with the C4 patch.
It should work for you, or we can take a look at yours—if it's compatible, we'll just install the patch.
yes,can work with c4. but if is truck xentry use oem c6 is better.
if is car xentry, can use c4 in 2025+ version after correct fix.
DTS9.04.016
MB software
M6+ Pro,C3
DS,Citroen,Peugeot Online
Lexus online//LatestGTS+2026 Offline/DST010
Hi. That's right, both of these devices are suitable for the job.
Hi! I'm downloading the 09.2023 image, split into separate files. The first file is an archive; I don't know what the rest are. Is this how it should be?
(03-30-2026, 09:32 PM)martsun Wrote: Hi! I'm downloading the 09.2023 image, split into separate files. The first file is an archive; I don't know what the rest are. Is this how it should be?
yes .the important is file 22xxxx gigas
Yes, download them one at a time.
I've downloaded all the files now. What program do I use and how do I mount the image?
Yesterday, 03:21 PM
Porshe
06-12-2026, 08:21 PM
Toyota
05-29-2026, 06:13 PM
