Xentry event log
Hi, Do you know where is the event log in xentry? Normally each problems should be written in some where...
What you need to know?
My Skype: Googly007
Mercedes SCN Coding & Retrofit
NTG Command Anti thief Code+SRS OFF and more.
I just wonder... which alarms deleted by dealer and when I using Citroen there was a event log in Diagbox software and you can check all event from there. You can understand if milage correction made somebody...
(09-16-2018, 07:52 AM)danrad Wrote: What you need to know?
xentry support tool - select mux - dianosis id1 - select VIN
Mercedes Comand/Audio antitheft codes all NTG
Mercedes Garmin Map Pilot Europe navi
Mercedes NTG5-6 Regio Software
Thanks given by: estebanfree
#5
(09-16-2018, 09:20 AM)A2ua Wrote: xentry support tool - select mux - dianosis id1 - select VIN
Where is the xentry support tool? Thank for your reply
On your desktop or Start/Programs/MB....
For sale: 5 Original Actia I+ME eCOM box. Comes in orig. box, manual, OBD and LAN adapter cable. PM for pricing.
#7
Thank you I found VIN number as you wrote and I exported as zip file. When unzipped file there were s lot of files. How can I find right file for car alarms?
(09-16-2018, 02:55 PM)Mackhack Wrote: On your desktop or Start/Programs/MB....
Thank you I found
Thank you I found
I dont know what you want to find so can recommend only to research yourself
Mercedes Benz Searching for XENTRY 12.2017 Xentry complete Folder anonimo 0 313 08-24-2018, 03:05 AM
Last Post: anonimo
Mercedes Benz Xentry startkey invalid for xentry developer V1.1.0 benz001 42 19,070 08-05-2018, 07:06 AM
Last Post: skull1
Mercedes Benz Xentry & DAS CBF's from Xentry 12/2015 CrAckJAck 3 2,875 03-25-2018, 01:25 AM
Last Post: can53
Mercedes Benz Xentry 2015_12: xentry.exe and start_xentry.exe needed Synthauri 4 2,391 03-21-2018, 04:30 PM
Last Post: pesona
  722.9 Can-Bus Log Request deviance 2 454 03-09-2018, 11:12 PM
Last Post: deviance
