Xprog does not read Cas2
Hello. I have Xpog-m 5.55 and trying to read cas2 MC9S12DG256 (2K79X) and ews4 MC9S12D64 (2L86D) with no result. I stop at "bypas security". I changed firmware to 551 by LuisAndre but it's the same. Please help, what do I have to do to make xprog work? ews3 reads very well.
Voltages on the bdm adapter when attempting to read:
Vdd - 5.1V
bkgd - 3.3V
reset - 4.4V
xckls - 50mV
bdm rev. C
Regards
try to schema R270 xprog 5.51 working perfect for cas 2 3
I connected with the schematic for r270 but it doesn't work
(02-07-2020, 08:52 AM)mlody20132 Wrote: I connected with the schematic for r270 but it doesn't work
post a picture with your connections
Sonder Hash Code & EZS Password Service, Ask via PM
They will have to pry the mouse from my cold dead hand.
Don't PM me for SW keys, Licences, radio codes or similar, you will not get any answer...
I have the same problem .. soft and hardware are same...instaled on win7 ultimate 32bit.
IF I HELP YOU PLEASE PRESS THANKS + REPUTATION
I had similar problems, but I tried Win XP and X-prog worked correctly, so for Xprog, Upa,and other clones I only used Win XP
Thanks given by: sparco442
Moje połączenie:
czerwony - + 5 V.
brązowy - GND
pomarańczowy - BKGD
żółty - reset
biały - zewnętrzny
zielony - xclks
.txt
foto.txt
75 bytes
(02-10-2020, 12:30 AM)mlody20132 Wrote: Moje połączenie:
czerwony - + 5 V.
brązowy - GND
pomarańczowy - BKGD
żółty - reset
biały - zewnętrzny
zielony - xclks
your link is crypted????
02-24-2020, 04:33 PM
AA+MHH
02-07-2020, 01:50 AM
02-02-2020, 12:14 PM
01-10-2020, 04:14 PM
Toyota
12-30-2019, 02:27 PM
