ZenZefi 2025 needed
HI, does anybody have zenzefi 2025? I need it since the newest I have expires on monday. Could someone point me in the right direction on where to obtain a new zenzefi certificate?
Thanks in advance Smile
Thanks for posting :-)
I have been looking for this for a while too.
All current certificates are valid to 12/24, so there is a possibility you get one valid for one more month, maybe a bit longer.
There was new ZenZefi introduced in XENTRY 12.2023, in which some algorithms were changed (I think?), so unless someone comes up with a solution, there will be no new certificates for import...
Leave thanks&rep if I helped youRauch15
(11-09-2024, 09:17 PM)waluskk Wrote: All current certificates are valid to 12/24, so there is a possibility you get one valid for one more month, maybe a bit longer.
Completely false, I have multiple certificates that expire in 2025 and quite a bit more than 1 or 2 months after 2024. Wink
Thanks given by: avandgarde , waluskk , Sam!k , keivin__2
If you have a way to get certificates from new ZenZefi then it is great news, however, to this day I was told that unless someone reverses the new ZenZefi, there will be no new certificate and I found no information saying otherwise.
Thanks for the reply, and sorry for my ignorance ;-)
There is no problem getting the certificate from xentry 09 2024 and using them.
DTS Monaco 9.04.016 all smrd working LIC Truck actuation, W206 Certificate, Xentry Ecom
Я могу установить его, но только если буду использовать свою установку Xentry.
Действительно до 27 марта 2025 г.
Thanks given by: s777786449
It can be installed on any new xentry with the proper fixes.
No fixes are needed, this is a wrong decision. The certificate is installed on the original zenzefi. The version with fixes is complete nonsense.
