bmw 328I 196 hp rpm disable
how can help me to disable rpm limit and abs off(if posssible),have abs faults in ecu.
For a good solution,will pay!
.txt
ecu id.txt
119 bytes
bmw e36 2.8 196 hp .rar
14
9 KB
I can raise rpm limit but you will not be able to fix abs just with file service
Skype.     barry.malone6
Do you solve this? I can make rpm limit
(06-13-2019, 12:54 AM)keytech Wrote: I can raise rpm limit but you will not be able to fix abs just with file service
That is not true, MS41 ecu limits 5200rpm when you have got abs/speed signal problems...
Here you have got your file with ALWAYS hard 7000rpm limit (even with abs/speed signal faults), pass PM, checksum has been calculated, just write it. Smile
RS3 8V2 nardo limo pl 600HP 700NM
109-Performance
Thanks given by: golf3ale
(06-15-2019, 02:29 PM)Mis32 Wrote: That is not true, MS41 ecu limits 5200rpm when you have got abs/speed signal problems...
Pm sent.
Your inbox PM memory is full, i cant reply.
109-Performance
(06-16-2019, 03:23 PM)Mis32 Wrote: Your inbox PM memory is full, i cant reply.
Try now!
You will not have full power if VSS error limiter is moved. RPM ok, VANOS not ok.
Life is to short to drive boring cars
(06-20-2019, 02:42 PM)Salt and sideways Wrote: You will not have full power if VSS error limiter is moved. RPM ok, VANOS not ok.
That is not true, using my solution vanos works like a charm, advance 25 degrees inlet camshaft even after 50km driven.
I know what im talking about, few years ago i have tuned 328i turbo using stock ecu, already made more than 50 times ms41 charged.
109-Performance
06-12-2026, 01:08 AM
06-08-2026, 08:08 PM
06-05-2026, 05:12 PM
