  • 4 Vote(s) - 1.5 Average
bmw e38 1998 gear fault codes
EGS :Symptom , gear monitoring
EGS: Gear monitoring 2 (P0732)
i check wires plugs and life data for turbin speed all look fine any idea please?
thank you
i had this fault code on E46 and found that the gear selector switch on transmission had water ingress due to faulty oil cooler and corroded all the contacts inside (sealed unit)
Thanks given by: oceandiver86 , iyad.nasser
thank you but selector switch is working fine i can read the live data on the gscan
05-08-2025, 08:46 AM
04-19-2025, 12:04 PM
