  • 3 Vote(s) - 2.67 Average
bmw e60 999km
hello, i change in dash km and in cas 10000 in cluster 130k, and mileage jumped to 999999km? soldering good, calculate good, read by upa erase, change writte m35080vp.. ideas? please
did you try to erase the 35080?
Work hard
Play harder
Thanks given by: samux
Solder again 35080
Or
35080 any time Damage need to replace ;-)
(06-01-2018, 02:57 AM)AutoHaus786 Wrote: did you try to erase the 35080?
just one time, erasse, upload dump change bytes and writte.. do it again..?
for first time it shows 996254, after that i look at cas but set is 129500, after that set to 10000, and then is 999999 in dash, read dash but its ok, no errors read or writte dash..with upa
rewrite original but might need new chip if its VP[/i]
yes its vp, but why need new, there are no errors read writte or verify, its so easy crash..?
in cas need to do 000km and connect the cas after have made change in cluster
not before.
(06-01-2018, 10:55 AM)ladadens Wrote: in cas need to do 000km and connect the cas after have made change in cluster
not before.
first i change cas after dash connect both to the car and then connect battery in cas and dash after9999 bytes not changed, same that i writte, its ok eeprom from e46 if i clear it and writte e60 dump?
its 35080 but not vp..? maybe eeprom fault but i can read it..
07-17-2019, 08:50 PM
07-11-2019, 10:29 PM
07-11-2019, 04:10 PM
Author: nafa
06-28-2019, 05:27 PM
06-08-2019, 01:12 PM
