bmw f30 2014 160D0WT chip mileage correction
19
(04-18-2020, 11:27 AM)ladadens Wrote: whrite first all original data to chip.and after this your km chnaged file.
https://blog.uobdii.com/how-to-use-xhors...e-red-dot/
thanks so much ladadens i realy appreciate it
i will try it soon as i odered vvdi red fix chip
Will report soon
best regurds
Sent from my SM-J250F using Tapatalk
thanks to all tried to help me
i replaced the 160D0WT with vvdi red dot fix chip and all is ok
no red dot
best regards
A question please, maybe little off topic here..
Is it possible to Reset KM on FEM without having to go thru with the whole process of opening FEM, reading eeprom, write, solder, desolder and so on?
I know the option "Reset KM" exist in both VVDI2 and BMW Tool but is it safe to use and does it work to directly just press "Reset KM" without removing and opening FEM?
So the idea is:
- Remove instrument
- Reset FEM
- 150D0WT on bench programmer to edit and then solder back.
- Connecting dashboard and should show mileage without tamper dot
Thanks in advance,
Best regards,
DeLuXe
79 Sharing is carying. Please press Thanks + Rep Button if my post is helpful.  Fing32
Any advice? Smile
Best regards,
DeLuXe
(03-04-2020, 07:42 PM)Autolab59 Wrote: buy new chip
If i rememeber after 2013 model you need to change chip ( i'm not sure about that)
Does it have to be vvdi red dot M35160DW chip? Or can I replace my original 160D0WT chip with another blank 160D0WT chip? Cluster is from 2013 year.
My original chip is damaged luckily I got original Dump of it by VVDI PROG.
Cluster is not booting up went blank. I'm assuming it has to do with chip being bad ISTA/D KOMBI is red ECU not responding.
NO you cant replace with any 160DOWT you will have RED dot . You need VVDI chip .
Use Thanks and REP button if I helped you..
(11-22-2021, 02:04 PM)pepi Wrote: NO you cant replace with any 160DOWT you will have RED dot . You need VVDI chip .
yes, you can replace it with any...
just use bmw explorer later and flash dash...
eeprom id will be turnfed off...
Thanks given by: Pak1s0ul , nikolaroma , gabur431
26
You think it will be cheaper with BMW Explorer $1,500 with basic VS $20 VVDI chip?
(11-23-2021, 01:22 PM)pepi Wrote: You think it will be cheaper with BMW Explorer $1,500 with basic VS $20 VVDI chip?
so it is now possible to exchange the EE or not..?
apparently it is possible...
but because you have nothing more sensible to do with it, you write something now about the price...?
do you feel hurt in your knowledge ..?
02-05-2025, 07:17 PM
02-04-2025, 09:08 PM
01-21-2025, 12:52 AM
