bosch me 7.7.0 with ktag clone possible
hello,
ist possible to read and write smart 1.0 turbo petrol bosch me 7.7.0 with ktag clone 7.020
thanks for all answers...
Good morning, did you clone kessv2? Is readable via obd2 write and read may not be a problem!
Have a nice day
Greetings from Stuttgart 653
(11-10-2019, 02:16 PM)FlorimStuttgart Wrote: Good morning, did you clone kessv2? Is readable via obd2 write and read may not be a problem!
i have kess 5.017 clone but i cannot found this ecu i menu to read via OBD.
you can read/write it by kess...
but not by obd...
check protocols...
you´ll have to open it and use resistor...
Thanks given by: harnaga
but not by obd...
check protocols...
you are rigght i dont check in protocols i will check and report
but not by obd...
check protocols...
Did you give me the current engine data? KW and year of construction?
Have a nice day
but not by obd...
check protocols...
Alientech does not have a protocol to read it through can bus/obd port...
the original has no protocol, let alone a copy...
no matter what year and or kW...
it needs to be opened and soldered...
if someone have ioterminal and bosch modul...
it could be read/write without opening...
but also not through obd port/can bus...
only direct connection ecu/k Line...
btw, if someone is smarter after reading my posts...
don´t be to shy to press THANKS and REPUTATION...
Yesterday, 06:56 AM
05-22-2020, 03:53 PM
05-10-2020, 07:13 PM
05-09-2020, 12:59 PM
