I have a camaro where i have changed from active suspension to normal suspension. Is it possible to flash the BCM, so it dosent look after the active suspension module.
[email protected]
camaro gen6 2016 lt1
05-01-2024, 06:51 AM
U should reflash BCM/ECM ect.., this model both with the suspension. detail need check the circure.
Thanks given by: Kepsus
Anything i can buy you help to, and what tool do i need gm mdi2 and some software or
05-01-2024, 02:39 PM
05-02-2024, 04:47 PM
(05-01-2024, 04:09 PM)Kepsus Wrote:(05-01-2024, 02:39 PM)Omantik Wrote:(05-01-2024, 01:43 AM)Kepsus Wrote: I have a camaro where i have changed from active suspension to normal suspension. Is it possible to flash the BCM, so it dosent look after the active suspension module.
write vin code of car to PM
Done
just write back if you need anything else
