  • 93 Vote(s) - 3.16 Average
carprog reprogramming by h-tag
10
All links are blocked .
Pls , reupload.
link mediafire work fine
Archive Download Blocked
links work good
ALL YOU NEED ABOUT CAR !!! [Image: i1cz2d_th.jpg]
Thanks given by: weiphyohein
14
Do not work links
(01-19-2013, 07:30 PM)Rumka Wrote: Do not work links
new link
16
(01-20-2013, 12:06 AM)diagmou Wrote: Hi.
Thanks for carprog.
please pass.
Cheer2
click button think's pass in P.M.
17
(01-17-2013, 10:02 PM)wahye Wrote: Here is how to reflash CARPROG Mcu AT91SAM7S256
In attach is solution how to, pictures, instructions, software, all info.
I manage to reprogram with success using a old Wiggler J-tag on LTP. Screen shot attached.
must be reprogrammed before counter go to 0
it's working for original and clone carprog just read info text in the files
BEFORE start programming:
- remove AT88SC (see picture AT88SC.jpg) from board before pogramming;
- connect carprog to USB or power supply (12v+);
- erase flash before (erase pin -pin55 from ARM- must lifted and connect at erase point 5-10 seconds);
- make sure that wires from J-tag are max 5cm long;
- make sure that J-TAG sw is set acording to H-JTAG.JPG and H-JTAG2.JPG.
Programming:
- connect J-TAG hardware acording to CONNNECTION_OF_JTAG_WIGGLER.JPG;
- use bin file AT91SAM7s256.bin;
- after programming, solder back AT88SC (pay attention to pin1);
- solder back erase pin (pin 55) from ARM back to board;
- make sure that 081105CAR001773I.lib is in same folder as CarProg.exe.
ENJOY your carprog FULL.
click thank's button Password in P.M.
THANK you , Will test it ... But exist some rumors about reset by USB ...
18
(01-20-2013, 03:56 PM)Rumka Wrote: Thanks please pass.
click thank's button and i will send you pass in P.M.
Programming:
it's tested work just read info.text if you don't knew 1 step ask?
Thanks given by: claxonul , mohcin2 , ocvirk darko , netacad7
Toyota
05-28-2020, 09:46 PM
05-28-2020, 05:04 PM
04-27-2020, 05:46 PM
